A/C recharge
Whats the best way to recharge the A/C system, i presume one of those cans with the connector...? Also when the light is on where it says off i presume it means its off?
Mine was down a can. I bought a new can and a filler connector thingy and went for it. Charged up, ice cold again.
The lights in the 850's are seriously backwards in my opinion. Who would make a light on when its off and off when its on?
A sealed system leaks no gas. But if it's only a slow leak I would recommend you get some of this
It worked well for me but follow the directions (ie make sure you run some freon in behind it or you'll seal your charging port) This stuff gave me a year or two then I had to replace the compressor. The super seal works great, easy to use and don't forget!! it will help save the environment.
