A/C recharging
Old Sep 8, 2007 | 11:16 AM
atb731b's Avatar
Default A/C recharging
Hi - just wanted to check with you guys. I need to check my freon level in my 1998 850 Turbo and I am wondering where the low side port is located. I did find a port on the left side (as I am facing the car) with a cap noting 6Nm on it - is this the port I should plug into?
Thanks for your help.
Al
Old Sep 8, 2007 | 11:44 AM
Default RE: A/C recharging
The low pressure port is behind the passenger side headlight on the frame rail.
I think the one you see is the correct one.
The 850's don't have a high pressure port.
Old Sep 8, 2007 | 11:45 AM
atb731b's Avatar
Tech, thanks, I am going out to give it a try..
Old Sep 8, 2007 | 11:58 AM
atb731b's Avatar
I just checked my A/C system and it is running about 37# certainly in the "normal" range, yet I am still not getting any cold or even cool air out of the system - any ideas as to what is wrong?
Al
Old Sep 8, 2007 | 12:01 PM
axelm's Avatar
Can you hear the compressor coupling? If not, bypass the low pressure switch that is close to the firewall with a paper clip or a cable to see what happens.
Old Sep 8, 2007 | 12:10 PM
ORIGINAL: axelm
+1
Old Sep 8, 2007 | 12:33 PM
atb731b's Avatar
Is the low pressure switch on the low pressure line? I pulled off the cable - i can just use a paper clip to connect the two terminals in the switch?
Old Sep 8, 2007 | 12:46 PM
That is correct.
Old Sep 8, 2007 | 01:01 PM
atb731b's Avatar
You are right. I jumped the switch and the pressure dropped to about 10 pounds. Can I leave it jumped until I find another low pressure switch to replace this one?
Old Sep 8, 2007 | 01:44 PM
atb731b's Avatar
Jumped the switch out - recharged the system to approximately 30#, I can hear the compressor kick in but no cold air yet. Any other thoughts?
Old Sep 8, 2007 | 02:08 PM
The system holds a little over 1.5 lbs You might need more.
Old Sep 8, 2007 | 09:14 PM
axelm's Avatar
If you bypassed the low pressure switch and you can hear the compressor working, put the ECC in defog, the temp in minumum and the blower in70%. Post the results here. Is your electrofan working properly?
heretic
Aug 30, 2009 06:49 AM
abflip567
Mar 25, 2009 06:22 PM
Maxbaby
Oct 9, 2007 04:59 PM
NoleWithAVolvo
May 15, 2007 06:25 PM
RedVolvo
Jul 28, 2006 10:38 PM
