cam sensor oil leak
Old Aug 13, 2005 | 04:10 PM
ttope's Avatar
Default cam sensor oil leak
I purchased a 1996 Volvo for my daughter and shortly after noticed a bad oil leak. The oil is leaking around the cam sensor around the top of the engine. I pulled the cam sensor off and noticed that someone had drilled a hole in it. I replaced this part and it is still leaking badly. Do I have a head gasket leak that is pulling in air and causing pressure build up in the crank case? Please help?
Old Aug 14, 2005 | 12:52 PM
Default RE: cam sensor oil leak
You need to replace the Cam seals.If it is leaking into the cam sensor then the seals are leaking.
joe maroon 850
Apr 2, 2011 02:04 PM
scooter101
Aug 6, 2010 01:49 PM
Scanman
Jan 28, 2010 07:01 PM
CassMori
Jun 19, 2009 07:13 PM
erndawg
Feb 13, 2009 10:14 PM
