Car hesitates when accelerating
Old Feb 4, 2015 | 11:14 AM
Radfordalum's Avatar
Default Car hesitates when accelerating
My 95 850 turbo hesitates at times when accelerating and the check engine light comes on briefly when this occurs
Old Feb 4, 2015 | 04:18 PM
I take it you have not seen any codes in the diagnostics. Do you notice it changing with weather? if your spark plug wires are shot they will arc when moist but work fine when dry (I've even seen the arc by idling in a dark garage.).. If you haven't done a full tune up - time for plugs/wires/rotor/cap to start with. Sometimes coils can go weak as well and don't put out enough spark for full throttle. I wouldn't think fuel if its intermittent but you may also want to test your temp sensor if the ignition tune up doesn't fix it.
Old Feb 5, 2015 | 02:51 PM
quick update. My car broke down like an hour ago. When I got it started, the yellow arrow started flashing and the check engine light came on. I got a ride home to hook my carmd up to see what is going on
Old Feb 5, 2015 | 04:21 PM
I'm getting P0120 (throttle position sensor ) code
Old Feb 8, 2015 | 02:11 PM
I changed camshaft position senor and it worked for one day.Most confused.don't know what to try next
Old Feb 8, 2015 | 02:30 PM
Did you try cleaning the contact to the throttle position sensor and measuring resistance for various throttle positions? Its a black box on the bottom of the throttle body... I've also seen other posts where a bad fuel pump relay or a bad injector relay can get the car to throw that code during a no start... not sure if that's true but it should be easy to check if you can get a used relay to throw in - I learned to keep a spare when I had an old Audi Quattro for just this reason!) Worst case is it may be the ECU (rare) or a wiring problem.
Old Feb 8, 2015 | 04:34 PM
H0lD mY d6InK's Avatar
Easiest and cheapest things would be ignition components (plugs, plug wires, rotor, and cap) if they are old, if not then I would check the vacuum lines to make sure one hasn't pop off or if any are just old and deteriorated.
These can cause hesitation and stalling or a no start condition.
Update; Ha Ha, just missed some of what you said also about the throttle code. Check out Rspi's video on that code
Old Feb 12, 2015 | 09:15 AM
For the week, I have changed the Throttle Position Sensor, the camshaft sensor and the alternator days apart of each other. After each job the car broke down again. What do you recommend
Old Feb 12, 2015 | 10:44 AM
firebirdparts's Avatar
If the car won't run, that is the time to figure out why it won't run. This requires testing, and sometimes a lot of testing. Do you have any interest in that sort of thing?
Also, I notice you're a Radford alum. Where do you live now? Just curious.
Old Feb 13, 2015 | 05:01 AM
I'm on the road again I changed the speed sensor last night and all is well thus far. Yeah, I attended Radford University for grad school. I'm Back home in Trinidad with my 850
Old Feb 13, 2015 | 12:13 PM
The wouldn't start once again
Old Feb 14, 2015 | 06:07 PM
Any codes?
If the fuel pump relay is old, just replace it.
Kat2012
Mar 27, 2012 07:39 AM
Armenian
Jun 15, 2007 06:11 AM
richsid
May 25, 2007 11:54 PM
Jutboy
May 24, 2005 01:15 AM
