Cd Changer and radio question
Old Nov 28, 2005 | 11:53 PM
Riculus's Avatar
Default Cd Changer and radio question
The antenna connection in my radio has a shot so the radio goes off iff i hit a pot hole. I changed the wires and it still happens. It seems that the connection inside after u plug the wires in is loose. can that be fixed by an electronic shop.
I also bought a pioneer 12 disk CD changer but I need the connector pin for the back of the radio where can I get that. Thanks for ur help
Riculus
Old Dec 5, 2005 | 01:01 AM
m1964's Avatar
Default RE: Cd Changer and radio question
Only Alpine CD changer will work with OEM radio so you could use radio to control Cd changer. W/ pioneer use FM modulator. As for antenna jack repair - I do not know. It should not happen (lose jack) at all.
Old Dec 5, 2005 | 09:37 AM
jcmartin's Avatar
The loose connection is unlikely to be the antenna. My guess is that you have either a bad (loose) ground or a broken power circuit. I went thru the same thing with my Saab, and was unable to fix it until I removed the radio, disassembled it, and cleaned and reinsethed the connectors and wires; and then I did the same thing for the wiring chassis connectors.
It can be done. In the Saab access was pretty good once the dash electronics were removed. I don't know about how the Volvo space and wiring issues work out.
JM
Ocotillo
Jul 14, 2010 02:29 AM
stickydub
Jul 8, 2008 12:33 AM
jmana
Feb 1, 2008 01:25 PM
TacklaNHL
Dec 20, 2007 01:55 PM
c70turbogt
Dec 9, 2007 07:35 AM
