CEL Help (Ignition Misfires. O2 Sensor Response, and an EVAP Leak)
Old Mar 21, 2011 | 08:39 PM
  #41
cmayo313's Avatar
Originally Posted by tech
I run Autolite coppers in mine and running 15PSI boost I drop the gap to .025 for the higher boost.
Yes Bosch makes bottom line and top line. The bottom line one does not have the black cover on it.
I think I still have my old Autolites which were used for a little over a week. I forget if they're coppers or not. I might drop the gap on the NGKs tomorrow if the CEL comes back on. I reset it after my last post and has been off since.
I'm also going to have a friend who works on Volvos for a living look at it either tomorrow or Wednesday.
Old Mar 22, 2011 | 05:57 PM
  #42
Did you say you have a MSD coil? I was under the impression that coil was only for high performance set-ups like stage III applications. That could be one of your problems if you are not tuned for performance, stage II+
Old Mar 26, 2011 | 12:00 AM
  #43
cmayo313's Avatar
Yes I do. How bad is it that I have it?
I've only been getting p0303 the last couple scans I have done.
It seems as if I have a sudden radiator leak now, but it only happens once in a while. After driving 45 minutes to school and idling in the parking lot, it leaks. I can't tell where it's coming from, but the passenger side plastic part of the radiator is wet. Once I drive home and park it in the driveway, it doesn't leak. Also when the engine is cool, it doesn't leak
BSCrouse
Oct 6, 2009 09:41 PM
awldune
Jul 31, 2009 09:14 AM
jsj_297
May 13, 2008 03:22 PM
vetalbig
Jan 22, 2008 01:19 PM
