Central Locking
Old Nov 21, 2007 | 11:52 AM
Quincy56's Avatar
Default Central Locking
I searched the forum, but didn't see an answer, so I'll ask..
I have a 95 850 Wagon. When I lock or unlock thedoor fromeither the passenger side or the drivers side, only that door locks and unlocks, as well as the tailgate. The rear doors never do anything, or does the opposite front door. Not sure if this is how it is "supposed" to work or not.
I have no "fob" and I don't know if the receiver is in the car for one.
John
Old Nov 26, 2007 | 12:01 PM
Default RE: Central Locking
On the 1995 all the doors should unlock from either cylinder.
Old Nov 26, 2007 | 08:11 PM
Quincy56's Avatar
Ok, I'm looking at the wiring diagrams, and there is one labled simply "Central Locking", one labled 2 Stage Central Locking and one labled Central Locking with deadlock. Any ideas how I can tell which one I have?
Also anyone seen a writeup on troubleshooting central locking?
Thanks
John
Old Nov 26, 2007 | 08:22 PM
You have single stage. I forget if they also call it deadlocking.
You have the same as my car and every other Volvo till the end of 1995.
All doors are controlled by the front doors mainly the drivers front door.
Old Nov 27, 2007 | 06:03 AM
Quincy56's Avatar
Ok, I found the troubleshooting guide (link here) http://www.volvoclub.org.uk/tech/service/850/KeylessEntrySystem.pdf
Now I have a couple of questions..
Where is the "central locking unit latch"? (mentioned below)
Ensure doors and trunk are open. Lock unit should be latched
in lock position by pressing in central locking unit latch with a
screwdriver.
Also where are the central locking relays?
Thanks
Old Nov 27, 2007 | 05:36 PM
The relay is under the dash on the drivers side.
They mean to manually lock the latch with a screw driver so the car thinks all the doors are closed.
But you will still have them open.
guptash
Nov 19, 2011 04:17 PM
Mass850
Oct 21, 2005 09:48 PM
test225
Oct 16, 2005 12:53 AM
giddingsw
Aug 11, 2005 02:00 PM
guptash
Feb 1, 2005 12:32 AM
