Central locking erratic
Old Apr 12, 2008 | 09:50 AM
guptash's Avatar
Default Central locking erratic
95 850 Wagon
Fact: 5th door lock does not open with central locking, it does close all doors when operated by key, I believe the lock needs to be changed. Normally central locking works great.
At times it gets erratic, while driving if I hit a rough road all doors lock on their own (which never happend in the past and I do not believe is a feature of this model unlike a lot of American cars). At times when I unlock the carit automaticallylocks back again immediately, this can happen a couple of times at a stretch. Sometimes the central locking locks up and normally the 5th door lock helps to unlock.
I am not even talking about the fob not working and I am fine with that.
Any help will be appreciated.
Old Apr 12, 2008 | 09:58 AM
Default RE: Central locking erratic
Does the alarm ever go off when you try starting the car and the doors lock?
Old Apr 12, 2008 | 11:23 AM
guptash's Avatar
Not every time.
I just keep trying to unlock after it automatically locks, usually after a couple of attempts it stays unlocked.
One time the alarm did go off but that was when the doors were not properly locked.
Old Apr 12, 2008 | 10:57 PM
Maybe run a Temp ground wire from the battery to the engine and one from the engine to body and see if that helps.
guptash
Nov 19, 2011 04:17 PM
Mass850
Oct 21, 2005 09:48 PM
test225
Oct 16, 2005 12:53 AM
giddingsw
Aug 11, 2005 02:00 PM
guptash
Feb 1, 2005 12:32 AM
