changing spark plug wires....
Old Dec 3, 2008 | 06:47 AM
chef's Avatar
Default changing spark plug wires....
Hi guys, well i think it will soon be time to change my spark plug wires....the date stamped is of 04...so they are now 4 years old....they do look to be in good shape though..
What i wanted to know is....do i need to change the cap and rotor as well or will just the wires do? i've never changed a cap and rotor, is it a tough job? thanks
fabs
Old Dec 3, 2008 | 07:46 AM
JPN's Avatar
JPN
Default RE: changing spark plug wires....
I think you can defer replacement for the wires for another 1-2 years, but it also depends on the mileage (I do mine at every 60,000 miles/less) as well. Are the wires you have now made by Bougicord? Bougicord, French, is the OEM for the 850s. I would do an Ω test on each wire, and if they pass then I would leave them for another year or two. If you insist, however,make sure to get Bougicord wires:
http://www.fcpgroton.com/category-ex...37/by_year/45/
If the cap & rotor have never been replaced, I would do both. No, the job is not difficult and any DIYer can replace them but make sure to number the original cap & wires just in case. I believe you need Allen keys for the rotor. Get a Haynes manual if you do not have one yet.
Other experts would be chiming in shortly for better assistance...
JPN
Old Dec 3, 2008 | 08:43 AM
I agree I would wait a little longer on them.
Old Dec 3, 2008 | 12:04 PM
chef's Avatar
Hey Guys, thanks for the reply...
JPN...yes the wires that are one there now are the bougicord ones with the date stamped on them...
I think i will wait a bit....but "santa" (the wife) was asking me what i want for Christmas...hmmm maybe i'll ask for that kit you pointed at...should i also change out the coil? (not included in kit)...
thanks
fabs
Old Dec 3, 2008 | 01:01 PM
outdoor7or24's Avatar
Test the wires with the ohm meter. Most of the time they are working or not working... Do you have any rough idle or feel a miss?
You don't need the coil unless its bad.
Wires, cap, and rotor. Thats all.
Hope this helps.
Old Dec 3, 2008 | 01:10 PM
chef's Avatar
hey, sorry for the ignorance, but how exactly do you test it with an ohm meter? i do have a multimeter...let me know..
Idle is okay, fairly steady. I do notice, mainly when the engine is cold, that at times when i give it throttle, the rpm's climb, then there is a slight feeling of it missing then it picks up again...
thanks
fabs
Old Dec 3, 2008 | 01:21 PM
Here is a good article - http://www.popularmechanics.com/how_...e/1272351.html
Take one wire off and test it - one at a time so you do not get them mixed up.
Take the spark plug wire and press the (+) test lead to one side and the (-) test lead to the other side touching the copper connectors. As this article states, you should come up somewhere in the range of 10k to 15k. Zero can indicate a bad wire.
You mostly notice a bad wire when the motor is under a load - taking off from a start, acceleration, going up a hill, etc...
Oh, if you have the spark plug boot pliers, those are a good investment.
Old Dec 4, 2008 | 06:47 AM
JPN's Avatar
JPN
>but "Santa" (the wife) was asking me what i want for Christmas
I would officially like to state that it is of utmost unfairness that you have a Santa...
.....Where is my santa!!!
JPN
Old Dec 4, 2008 | 07:27 AM
chef's Avatar
hahahah sorry Jpn...can't help you on that one..what i can say is that I also have a tough time getting Santa to understand why i work hard on trying to keep my volvo in good shape. Santa and cars don't always get along...hope this helps..
fabs
Old Dec 4, 2008 | 02:57 PM
JPN's Avatar
JPN
Thanks.
In Northern Europe, Santa drives a Volvo... or his reindeer is turbocharged...with Check Engine Light always on...let alone ABS warning...
JPN
futbolfan15
Apr 2, 2010 09:56 PM
colgate41
May 11, 2008 11:22 AM
MattB850in
Apr 13, 2007 11:12 AM
go2sharks
Feb 17, 2007 01:10 AM
defuse
Jul 18, 2005 10:34 PM
