Check Engine light
Hi Folks,
Another happy 850 owner
My check engine light is now on, actualy has been for a while along withthe other on and off lights for ABS, TRACs, etc...
Anyway, took the car (96 turbo wagon) to Autozone for them to read the codes, and they said they could not - does it take a special reader? Where can I get one?
Need to get the caar inspected this month and they won't do it with the light on. Can I clear the light by disconnecting the battery?
Thanks,
mike
-My check engine light is now on, actualy has been for a while along withthe other on and off lights for ABS, TRACs, etc...
Thanks,
mike
A regular OBDII scanner will read the codes on a 1996 car.
Either try another Auto Zone or a different person at that one.
No disconnecting the battery won't clear the codes/light.
I took the car to a different AZ, and sure enough they read the codes. Bad O2 Sensor, bank 1 #1. Two questions,:
Is this difficult to relplace?
How do I get the codes cleared, I read a posting that indicated the possibility of conditions that will cause the O2 sensor to appear bad, but actullay be ok? Would like to trhy this before i invest the time an $ in the sensor.
Many thanks,
Mike
Many thanks,
Mike
Usually a vaccum leak is the only main thing that will throw the code.
But if it came up as front HO2 sensor heated circuit then the sensor is bad.
If is fairly easy to replace the worse part is getting your hand to the plug to unplug it.
Thanks,
I am going to invest in an ODB II reader for this car, check the vacuum lines and go form there, Thanks, for the help. Amazon has a good reader for $69 - the same one they used at AZ...
I'm curious as to the specs of the OBD-II reader.
Actron's CP9175 is an excellent scanner, which was used at an AZ in Chicago when I worked there. But the quality comes at a price (approx $160) and it was made in the USA. The downside was that it was only able to access engine & tranny ECUs.
When it comes to electronic control system diagnostic equipment, I have 100% trust on Axelm of Argentina.
JPN
JPN
ORIGINAL: JPN
EDIT: I found the post with that info. thanks
The remote has 2 switches with 4 positions: forward, reverse, left and right. It also has a LED. That is enough to read the codes off this car. The LED blew because ir could not stand 12V, so I had to use an analog multimeter to count the amount of pulses.
LOL, my business partner is an Electronic Engineer. I don“t think he shares your opinion about my electronics skills. But since I say the same about his c++ development skills, we call it even.
ErnstlS90
Oct 23, 2008 08:37 AM
