Check engine light on - AGAIN!!
Old Jan 16, 2008 | 02:55 PM
ddorshimer's Avatar
Default Check engine light on - AGAIN!!
I am working on a '96 850 Turbo that had the check engine light on with 4 codes that I was able to pull.
They were:
Low power to O2 sensor #1 (p0130)
Slow response from O2 sensor #1 (p0133)
Low power to O2 sensor #2 (p0137)
Fuel system rich (p0172)
Upon seeing that 3 of the 4 codes were directly tied to the O2 sensors, I took the deductive leap that there was a problem with the O2 sensors that were currently installed in the car...one was likely the original, and one was replaced with a universal as some point.
I purchased the OE sensors from IPD and installed them, cleared the codes and proceeded on my merry way thinking that the problem was solved.
The light came back on today. I will pull the codes and post them later today, but does anybody have a thought as to what else could trigger this response from the ECM?
This is getting rather frustrating.
Old Jan 16, 2008 | 04:57 PM
ShaginWagon's Avatar
Default RE: Check engine light on - AGAIN!!
"Low power to O2 sensor #1/2"
Wouldn't they both be recieving power (5 volt) from the ecu ?
Maybe check that with a multimeter.
If their earth wire is not making a good conection that would also upset their "power".
Note*** I have no idea about where or how they are earthed, just seems like a logical thought to me.
Maybe go over all earth points and check for loose connectors.
Old Jan 16, 2008 | 10:34 PM
JPN's Avatar
JPN
Or there may be a vacuum leak somewhere, most likely from the elbows. Double check on them.
JPN
Old Jan 16, 2008 | 11:00 PM
ddorshimer's Avatar
The code that came back was the P0133...slow response from sensor #1.
I thought about the grounding, but that doesn't really explain the slow response code...
Old Jan 17, 2008 | 07:43 AM
Ozark Lee's Avatar
A dirty MAF (AMM) sensor can cause the same error. Pick up a can of electrical contact cleaner or MAF cleaner and spray the MAF down. Don't scrub it, dry it, or even touch it.
...Lee
cioara
1998-2000 model year V70
Sep 24, 2014 07:25 AM
hairyg
Oct 4, 2009 07:31 AM
crystalfleet
Jan 16, 2008 07:30 PM
quarterdimenickel
Dec 2, 2007 01:22 PM
