child seat anchor simple question
RE: child seat anchor simple question
AJ,
According to the owners manual Canadian cars were provided with one anchor that was in the Glove box. If anyone installed it you would find it under the rear deck on the sedan, or on the back of the rear seat in a wagon. These cars are not equipped with the LATCH system. You will only use the anchor for a forwarded mounted seat. A rear facing child seat does not incorporate the anchor. You also will not need the seatbelt locking clip, as Volvo's have the child/adult toggle switch on all seat belts except the driver's. If you need to order one- I recently got one and could not find it through an online retailer and had to use the dealer.
hope that helps,
Justin
hope that helps,
Justin
Thank you, I will send my dad to Volvo Dealer in Montreal to get one , My daughter had the Federal Inspection done yesterday and failed it because of the day light. I tought the one Volvo 850 had were ok but shecould turn them off which they don't want. module $25.00 installation $150.00
after the fix she will get the federal stamp. Next will be the Provincial inspection which is mechanical .
Thanks AJ
Thanks AJ
ORIGINAL: jnduke
Thanks,
Axel
It's just the little red button on the back of the seat belt clip. The 'child' selection keeps the lap portion from slacking when you have the seat installed. It's so you don't need the little H shaped clip to lock in the tension on the seat belt. Just push over that red button, and cinch it down till your heart's content.
HI,
My Dad bought a anchor from Volvo in Canada for $32.00 and installed it. Now we are ready for the Provincial inspection on Wednesday. , About the day light....thanks axelm I called Volvo and they confirmed that there were a screw to turn on Daylight, I called the Federal inspection service station and they will remove the module that they installed and give my daughter back her money. ($175). I am glad that you told me aboutit. [sm=thanx.gif][sm=yeahsmile.gif]
Donate $20 to this charity and we can call it even ;-)
http://www.feliceslosninos.org/en/no...ienvenida.html
bond007
03-24-2011 12:12 AM
