Clunk while idling
Old Mar 28, 2008 | 09:55 AM
zake's Avatar
Default Clunk while idling
1996 Volvo 850 GLT
163,000 miles
After I have driven the car for between 30-60 minutes there is a clunk that will occur somewhere in the engine bay while sitting and idling. I don't know if this is possibly a problem when the fans are engaging or possibly the alternator. The transmission has never given me any problems. Shifts into each gear fine and never slips or stutters no matter how hard I get on it. Any help would be appreciated.
Old Mar 28, 2008 | 10:00 AM
JPN's Avatar
JPN
Default RE: Clunk while idling
It could be anything; finding the source of a noise is one of the hardest tasks, and not being able to see it makes it even harder.
I would check the engine mounts but see if you can hear from Moderator Tech.
JPN
Old Mar 28, 2008 | 05:39 PM
Volgrrr's Avatar
ORIGINAL: zake
1996 Volvo 850 GLT
163,000 miles
Bearings in the serpentine belt tensioner on the way out?
Old Mar 29, 2008 | 11:12 PM
bitter356's Avatar
While the car is in park and the engine running, defrost off, observe the tensioner pulley.If it is vibrating greater than 1/4", the tensioner is the culprit.
Old Apr 7, 2008 | 04:14 PM
TOm93R1's Avatar
I get the same clunk. Never does it once I start moving.
My tensioner definately is on its way out, so good chance these guys are correct!
thanks for the hint, I have been wondering what the noise is for as long as I have had the car (about a year)
Old Apr 7, 2008 | 05:36 PM
Svtfiveoh's Avatar
I get a thump or a clunk on the driver side almost behind the driver side fender.. It only happens once its warmed up.It almost sounds like when you turn off the car and its cooling down and you a tink tink or clunk clunk.....
lukaspanic
Mar 17, 2011 12:32 AM
jasonbrown58
Dec 12, 2007 05:18 PM
Mercury
Mar 21, 2007 04:15 PM
meehaneo
Jun 27, 2006 12:07 AM
YOLY
Nov 15, 2004 02:59 PM
