Clutch stuck disengaged
Old Feb 14, 2011 | 02:31 PM
300K740's Avatar
Default Clutch stuck disengaged
96 850 wagon with manual transmission.
The other day clutch pedal was pressed and now will not return. The clutch is permanently disengaged (engine not powering the wheels). Clutch was feeling a bit low but was still very driveable.
This is opposite what I would expect to happen if there was a leak, maybe the slave cylinder pushed out too far and got jammed?
Any clues as to what this could be? I have never run into an issue like this in a manual before.
Thanks
Old Feb 15, 2011 | 08:44 AM
kvangenechten's Avatar
I had this issue on a BMW, I needed a new clutch. The pressure plate went bad.
Old Feb 15, 2011 | 11:52 PM
gdog's Avatar
Yep; your pressure plate probably let go...
Could be the clutch slave cyl is stuck all the way out, but i would still bet on pressure plate...
Old Feb 18, 2011 | 08:05 PM
300K740's Avatar
It was the pressure plate unfortunately,
Thanks for the help
gentlejax2
Jun 18, 2012 03:19 PM
redrider7202
Mar 6, 2010 02:04 AM
nehopsa
Jun 24, 2008 11:20 AM
