Code 123 + reving motor + Fan on when starting *fixed*
Okay so you may have read the surging idle [https://volvoforums.com/m_119160/tm.htm] and broken thermostat housing bolt [https://volvoforums.com/m_119161/tm.htm] posts. Got the IAV cleaned, and drilled out thermostat housing bolt and replaced with hex. Found out the thermostat was broken [just like my 945t, only seen this on volvo's and none of my other makes], replaced with 87 degree thermostat from FCPgroton and got it all put back. Got the last fuel injector seat seal that was in stock in Athens, GA this weekend. I went to the UGA game, Go Dawgs!
Now Fan runs as soon as you turn the key, the motor is back to reving sporatically, and I got code 123. Put Ohm meeter on coolant temp sensor and getting sporatic measurements to finally 0 ohms.
So, I am gona order the temp sensor.
BUT, what else should I maybe check??? Since I have to order, I'd like to get everything at once. Any ideas?
