Code P0300 / Lucky quick fix
Old Oct 23, 2011 | 03:33 PM
mikwik's Avatar
Default Code P0300 / Lucky quick fix
(96 glt n/a 117k) My son quickly lost acceleration 5 min. into a trip and nursed the car home on the highway, bucking, choking,and almost stalling especially when going up hills. He said it didn't seem to shift up. Cel on : code p0300 (random, multiple misfires) came up plus 301, 302, 303 & 304. I changed plugs, rotor & cap last year when p0300 came up under same circumstance, and I don't believe all the plug wires would go at once so I figuered coil or coil wire might be the cause this time. However, I remembered how my truck is sensitive to moisture in the gas tank, and we had damp, foggy weather this week. He said there was only a few gallons in the tank and it wasn't driven all week. I filled it with good gas (I like Shell), put fuel conditioner in and 5 miles down the highway after it smoothed out I cleared the codes. Put another 20 miles on it; very responsive never skipping a beat, running great.
Hope he learns a lesson: don't make a habit of keeping just a little, cheap gas in the tank (yes, he ponied up for the tankful !)
My lesson: continue to check the easy stuff first (plenty of time to curse later)
Old Oct 23, 2011 | 09:36 PM
You might want to check/change the fuel filter too, just in case. The lower the fuel level the harder the pump has to work pushing the fuel through the filter.
Old Oct 24, 2011 | 06:39 AM
mikwik's Avatar
will change filter. it's due. thanks for the heads-up
bigsparky
Feb 19, 2015 06:36 AM
ness710
May 16, 2011 11:18 PM
jeffreydoctor
Feb 20, 2010 02:18 PM
sj6700
Jan 18, 2009 04:41 PM
fritzlovesmary
Dec 6, 2007 09:33 AM
