code p0500
Old Feb 9, 2006 | 09:41 PM
sp5368's Avatar
Default code p0500
Vehicle speed sensor correct ,where is it located 0n 97 850 and can this limit rpm when going bad
Old Feb 11, 2006 | 05:34 PM
Default RE: code p0500
What system did you pull the code from?
Old Feb 11, 2006 | 11:57 PM
sp5368's Avatar
I am not sure of the question but my check engine light was on after a dyno and P0500 was on my OBDII . Tech can you explain your question thanks.
Old Feb 12, 2006 | 12:33 AM
Did it come from the engine,trans, or ABS system. If you had it on the dyno then most likely it was an ABS code because it was on the dyno. The front wheels were moving and the rear werent and that would mess up the system.
But if cleared it should stay out.
Old Feb 12, 2006 | 12:46 AM
sp5368's Avatar
Yes is has cleared but this is the first time I have had this problem on a dyno the last 4 times on a different dyno did not get the cell.Thanks for tech for responding
Old Feb 12, 2006 | 12:55 AM
No problem see what happens from there.
RomoGuy
Jun 10, 2017 11:08 AM
Radfordalum
Jul 21, 2015 09:30 PM
Charles E. Kennedy
1998-2000 model year V70
Sep 29, 2014 11:34 PM
charles_snorton
Dec 21, 2010 12:02 AM
Chebucto
Feb 21, 2010 07:10 AM
