Cold start problems on 2.3 turbo 850
Old Dec 17, 2007 | 10:26 PM
240maybe's Avatar
Default Cold start problems on 2.3 turbo 850
ok, i find this problem strange. the car runs and startsperfect when its warm outside or when it has been running and warmed up, BUT if the car has been sitting outside in less than 40 degreesfor around 4 hours or moreit will crank, start, and die. i will do this about 30 times then finally it will start and stay running. this does this only when cold. after several starting attempts i hear a buzzing/grinding noise comingfrom in the dash,a few starting attempts afterthis happens the car will start. oh and after every start attempt ihave to turn the ignition to OFF or it will not start at all andonly crank over. this is my only car any help is greatly appriciated. thanks in advance
-chris
Old Dec 18, 2007 | 08:05 PM
Default RE: Cold start problems on 2.3 turbo 850
Sounds like fuel pressure is bleeding off.
Old Dec 18, 2007 | 09:00 PM
JPN's Avatar
JPN
And if you hear buzz from around the dash, the fuel pump relay could be a culprit.
http://www.fcpgroton.com/volvo850fuelsystem.htm
JPN
jpm2346
Dec 23, 2016 02:35 PM
biggmo
Oct 13, 2008 09:15 AM
arttu
Feb 15, 2007 10:16 PM
nick54
Dec 22, 2006 08:47 AM
profuse007
Apr 29, 2006 01:03 AM
