240: cold start problems... HELPP!!!
Old Mar 7, 2006 | 03:36 PM
profuse007's Avatar
Default 240: cold start problems... HELPP!!!
hey,
i have several problems w/ my '92 240. when I 1st start itup in the morning and try to put in into gear and it stalls out. however, if i wait for ~15min for it to warm up, then theres no problem w/ engine stalling out.
thanks for your time,
Tran
Old Mar 7, 2006 | 09:03 PM
Default RE: 240: cold start problems... HELPP!!!
Try cleaning the throttle body and idle motor first and see what happens.
Old Mar 8, 2006 | 11:13 AM
profuse007's Avatar
i recently had a major tune up. also, the thottle body and the idler motor was clean but the problem still appear.
Old Mar 8, 2006 | 08:35 PM
Might be a bad coolant temp sensor then.
Old Mar 8, 2006 | 08:42 PM
jfunez's Avatar
that sound possible,since it only happens in mornings when cold,ctp should tell computer to enrich the mixture ..
[IMG]local://upfiles/4632/C1815D91A331455BACF6C4423B43D893.jpg[/IMG]
Old Apr 28, 2006 | 12:40 AM
gerald's Avatar
Hi! Please help me. I`m having a big problem with my volvo, is a 240 DL`98, sedan, Like a month ago I was drivingand suddenly the car started to stall and I had poor acceleration. First tought was that iI needed tune up, which I made the day after, I changed all I could to have a good result:
All failed, still got stalling engine,lack of performance totally bad. The most i can get is 30 35 mph. It seems like the exhaust system is clogged.
Even i replaced the catalyzer, I don`t know what else I can do. Please for sure somebody must had the same problem. Help! Thankyou.
Old Apr 29, 2006 | 01:03 AM
Did you replace the Fuel filter?
Do you hear Both fuel pums running?
chrisvolvo850r
Jan 18, 2012 07:44 PM
thullz
Dec 5, 2007 06:46 PM
arttu
Feb 15, 2007 10:16 PM
nick54
Dec 22, 2006 08:47 AM
pmvictory
Dec 15, 2006 02:21 AM
