cooling fan will not shut off
Old Mar 22, 2011 | 03:48 PM
northeast eric's Avatar
Default cooling fan will not shut off
i'm thinking the fan relay on my 94 850 turbo is shot. i have to pop the hood and pull the plug going to the fan motor everytime i park as well as leave. has anyone with any experience ever seen this? oh yeah and my code reader doesn't work so don't bother asking.
Old Mar 22, 2011 | 10:31 PM
Aftermidnight's Avatar
I think your diagnosis is correct in being the cooling fan relay.
Old Mar 22, 2011 | 11:27 PM
ibified's Avatar
if it isnt the fan relay, it's the car putting itself into limp mode for some reason.
Old Mar 23, 2011 | 03:02 AM
i will replace the relay and keep everyone posted. i'm curious about what limp mode is...
thanks guys.
Old Mar 23, 2011 | 02:52 PM
hookuspookus's Avatar
relay
Old Mar 23, 2011 | 09:46 PM
Henry10's Avatar
Fan Relay has the ECC contacts normally-closed, while the ECU contact is normally-open. When ECU detects ECT over a certain temp, it closes the latter contact. When ignition is turned off, ECU should switch the fan off after 30 seconds. I think the normally-open ECU contact, which is closed at this point does not open, hence shut down the fan. This causes the fan to continue to run.
rolandt
Oct 16, 2017 12:24 PM
jonqu
Sep 9, 2013 12:31 PM
Dainos
Oct 3, 2009 08:30 PM
moros323
Jul 26, 2008 09:00 AM
