Correct 94 850 turbo timing belt kit?
Greetings,
Just bought a used 850 turbo 94. Don't know when the timing belt was changed, so I'm going to change it ASAP. However, I can't see to determine the correct timing belt kit for my 94. I see some information states if the serial number is after 131xxx then it is the same kit as 95 to 97 850s. However, if it is less than that, then it is a different kit for 93 to 94 850s.
On my timing belt cover, I see 2 sets of numbers
Artikel NR 1289853
Serie NR 292685
My VIN is VIN: YV1LW5715R2072492
Can someone please tell me which kit I need to order? Thank you !
Artikel NR 1289853
Serie NR 292685
Thank you very much!
jefferino
Jun 8, 2013 03:06 PM
deathbots
Jan 1, 2008 02:55 PM
