correcting engine timing?
Old May 24, 2021 | 05:08 PM
gruey15243's Avatar
Exclamation correcting engine timing?
so I'm in the middle of changing the timing belt, water pump, and idler pulleys on my Volvo 850 turbo, and I realized halfway through that I did the timing wrong (didn't line up the tics to the lines on the crank on the engine). I already have the belt, and idler pullers and tensioner out but is there a way to adjust the timing after I replace everything? or can I rotate the engine now?
Old May 24, 2021 | 08:57 PM
If you have the belt off and rotate the crank or the cams too much you will bend valves.
Old May 24, 2021 | 09:00 PM
gruey15243's Avatar
so should I wait until I put the new belt on to adjust the timing?
willbr
Sep 17, 2017 12:36 PM
jeremygreg
Apr 14, 2010 04:12 PM
boxpin
Feb 23, 2010 10:32 PM
gmorgan
Engine & Internal
Jun 12, 2007 07:53 PM
landaurod
Dec 16, 2006 10:36 AM
