cost to replace Heating core
Old Feb 21, 2012 | 06:14 PM
940glowner's Avatar
Default cost to replace Heating core
hello again everyone. does anyone have an idea how much it would cost me to properly replace a bad heating core? what kind of damage could it do to a 96 850 if it wasnt replaced?
thanks
Old Feb 21, 2012 | 08:44 PM
Jy core (if it looks newish), $15, do the job yourself, Priceless!!!
If your heater core is leaking, it can get worse and loose a lot of coolant, in which case can cause you to overheat your motor and GAME OVER.
If you take it to a repair shop, they should be able to replace it in an hour. They will likely need the firewall coupling so between the $150 core, the $35 coupling, a little coolant and the labor, you're likely looking at about $285. At the stealer, likely about $425.
Old Feb 22, 2012 | 11:44 AM
What he said.
Old Feb 23, 2012 | 12:07 AM
boxpin's Avatar
smelly, stinky, soggy and rotting if you dont.
Old Feb 23, 2012 | 10:03 PM
daver80's Avatar
Default heater
I didnt notice any coolant loss, I just smelled the sweet smell of pancake syrup. except it wasnt pancake syrup. I figured I was poisoning myself driving a car with that ethyl glycol (or whatever coolant is) vapor blowing right in my face so I changed it out! D
Old Feb 23, 2012 | 11:50 PM
gdog's Avatar
thanks
Sometimes i don't understand you guys; he said to "properly replace a bad heating core"!!
Why put in another worn out part in after the first "used" part failed?
Go w/new and go OEM; here you go:
1993-1997 Volvo 850 Heater Core
Like the other guys said, DIY is easy; here's one guide:
Pics Of Heater Core Install - Volvospeed Forums
Old Feb 24, 2012 | 04:24 AM
No one suggested that he put a "worn out" part in his car. The junk yards are full of parts that are new or near new. A heater core will likely last betwen 10 and 13 years. Just doing the math, most cars have had them replaced with the past two years. So, if you pull a part out of a car and it looks black, full of grime, and is obviously leaking, keep walking. However, if you pull the part and it looks like it's 3 days old, pay the $10 and install it in your car.
Sad as it may sound, not everyone has $120 to purchase a part for their car. (And yes that would fall under the catagory that "one can not afford to drive")
Old Feb 24, 2012 | 11:22 PM
What did you end up going with and how did it go for you ??
cjaama
Jun 26, 2013 07:37 PM
FreddipiXC90
May 31, 2011 07:10 PM
kidcudi
Jun 10, 2009 10:05 PM
