Cost to Swap Automatic for Manual Transmission on '96 850?
Old Dec 7, 2016 | 01:19 AM
  #21
tryingbe's Avatar
Newer Volvo are more expensive to maintain.
Sure, you can take chances with your FWD car, but it doesn't sounds like you want to keep it.
RWD cars were much more reliable, take abuse well, and last a lot longer than FWD/AWD cars.
Non interference engine, timing belt breaks? put on another one and go.
Solid rear axles, no cv shaft with rubber boots
Overbuild basic common RWD transmission that were used in other cars, instead of unique made for one five cylinder car with space constrain.
Stock smaller 14-15 inch wheels compare to 15-17 inch wheels, cheaper to buy replacement tires and less likely to have bent/damage wheels
Cheaper replacement parts, look up prices for timing belt and waterpump.
Turbobricks Forums - Powered by vBulletin
Go ask their yourself.
Old Dec 7, 2016 | 03:00 AM
  #22
CooperWalker's Avatar
I have to say as I am searching for a replacement vehicle, I can't help but love these early 90s Volvos I come across. What's your take on this one, for 7k?:
1991 VOLVO 240 WAGON 1 OWNER 168K MANUAL!!!
It has to be the cleanest looking car for it's age I've ever seen. I love the old school look and feel of those cars and you're right, they're very easy to work on and keep up. I absolutely understand your point, I am just drawn towards the idea of having a newer vehicle after almost 10 years in mine. Would you rather put 7k into something like this 240 with 160k miles on it or into a newer V70? I know you're going to say put 1500 into something like the 93 you sent and spend the rest on upkeep...
Old Dec 7, 2016 | 06:17 AM
  #23
tryingbe's Avatar
Personally, I don't like 240, they drive like a truck. They fine vehicles, I just don't like driving trucks. The manual M46/M47 is kinda weak, 5th gear is a o/d unit that frequently doesn't work.
Are you trying to have a collection of your own or are you trying to find a daily driver? Though that 240 is probably own by someone who took real good care of the car, so it would not be a bad buy. My sister's 240 have 238k and it does not use a drop of oil between the 5,000 miles oil change.
Old Dec 7, 2016 | 06:45 AM
  #24
No I'm looking for the cheapest and most reliable option for a daily driver. The 240 I showed you is a reputable car, I've never heard a bad thing about it. What in your opinion would be the best option for a used Volvo, with 2k - 2500 all in as a high?
Old Dec 7, 2016 | 09:33 AM
  #25
You can check out a used 740 or 940 as well. Manuals are less risky - clutches do need to be replaced from time to time and are less complex than automatics - but the Aisins used by Volvo are also used by Toyota are generally reliable if cared for, so they are not a weak link IMHO. The thing about the 240s is many of the common faults can be fixed by DIY. If you take the approach that a car's cost is a monthly transportation allowance, then you can also consider buying a beater (say a car with dents etc) for say 1500 and use the difference to pay for the occasional repair.
Old Dec 7, 2016 | 09:44 AM
  #26
Hard to argue with that, I admit. Thanks for the input, I will add the 740 and 940 to my list. Although I really need a wagon to support my equipment, roughly 400 lbs and big.
Old Dec 7, 2016 | 07:12 PM
  #27
tryingbe's Avatar
This, get it, get it now. Don't even post.
You know whoever owned it took GREAT care of it, and I bet he even have the receipts for all the work done to it.
https://orangecounty.craigslist.org/cto/5908795404.html
Dfunk
Oct 3, 2015 07:50 PM
ded137t5r
Jun 25, 2013 01:15 AM
mathieu_p
Jan 19, 2013 02:06 PM
1995Volvo850
May 12, 2012 09:15 PM
SDvolvonewB
Feb 22, 2011 11:26 AM
