Dashboard Lights Out. (1995 GLT 850)
Old Aug 26, 2012 | 09:16 PM
nownow's Avatar
Default Dashboard Lights Out. (1995 GLT 850)
Hello: When I first got this car the dashboard lights were not working. I thought it may be the dimmer switch. I banged the dashboard a bit with my hand hoping a loose wire would be the culprit, but nothing. Then I swapped out the fuse (#35) and that lit it up. This was fine for few days but now they are off again. It tried swapping out the fuse again but no luck. I would hate to put in a new dimmer switch because that would involve taking the dashboard apart. (Unless someone know an easier way of doing this.) Any suggestions out there?
Old Aug 26, 2012 | 10:02 PM
The dash dimmer switch simply pulls out, no dash removal necessary. I have a spare if you need it (pm me).
Old Aug 26, 2012 | 10:19 PM
nownow's Avatar
Thank you rspi for the offer. I actually have one that I took out of a car at the jy.. How do you pull it out? I had to push a dash board up and get the screws loose on the side to get to it. It came in two parts.. How does it pop out? I will try doing this tomorrow..
Old Aug 27, 2012 | 09:59 AM
nownow's Avatar
I see your instructions on the forum with the pictures....I will do it that way..
http://www.atthetipwebs.com/technolo...ash_dimmer.htm
Old Aug 27, 2012 | 09:30 PM
nownow's Avatar
Well I replaced the dimmer as per the instructions, changed the fuse and still no dashboard lights...thank you anyway..
Old Aug 28, 2012 | 02:38 AM
Brick850's Avatar
quite often it is the headlight switch itself that is the culprit. Mine would turn off at random, and my switch was at fault.
Old Aug 28, 2012 | 06:16 AM
nownow's Avatar
Thanks man. Ill check it out!
Old Aug 28, 2012 | 07:56 AM
Are any of the lights in the center console working?
tgfj53
Aug 7, 2014 12:59 PM
Daniel Sendelbach
Jan 11, 2014 07:29 PM
MarkyD
Feb 2, 2006 06:12 PM
danny
Sep 19, 2005 01:53 AM
