difficulty changing out flame trap
Old Feb 27, 2013 | 06:50 PM
xingchow's Avatar
Default difficulty changing out flame trap
Greetings!
My 1995 850 non-turbo has been smoking like a factory so I thought to change out the flame trap. It's pretty easy to identify but I've run into a problem: the PVC tube that connects to the throttle body won't come off. I've slackened the ring but it still seems not to budge one bit!
What am I missing here? This should be really simple.
Thanks for any advice/ guidance you can offer.
Old Feb 27, 2013 | 07:12 PM
T5850's Avatar
Should be simple? I've changed it on a turbo twice but i'm not sure if the non turbo is the same. should be able to pull it out maybe some silicon spray would help
Old Feb 27, 2013 | 09:50 PM
Usually they are baked in place almost like glue but if you run something around between the two they slip off nicely. Something like a small screwdriver or pick. Slide it between the two and work it back and forth. A little spray lube wouldn't hurt.
Old Feb 27, 2013 | 10:22 PM
I usually twist the hose connection to break the seal loose. Then pull it apart.
Old Mar 9, 2013 | 12:07 PM
xingchow's Avatar
Thank you all. I changed out the flame trap!
I do notice that my car is still smoking though. It burns through its oil every 2.5 weeks and goes low on coolant about every month. Any thoughts?
Thanks again!
Old Mar 9, 2013 | 01:33 PM
Well ,,, headgasket pops to mind but I don't want to say it
So, do you see an place you might be leaking coolant, checked all the hose connections ?? Radiator seams ?? Do you smell anything "sweet" when you have the heater on ??
If you don't see anything you might want to get a loan of a cooling system pressure tester with the correct adapter for connecting to the threads on the reservoir to pressure test the system and see if anything "pops" out. Sorry, bad pun.
Do you have any oily residue in the reservoir ??
When you did the flame trap did you replace it with a new one and did you replace the hoses too ??
Did you clean out the passages in the block the black box connects to ??
If it's a turbo did you remove and clean out the PTC ??
Some times it does take a few miles for the smoking to subside. I don't understand that but I have read posts advising people to drive it some before getting concerned about the continued smoking.
And of course, there is always a small chance it's well worn and you just have more blow by than the PCV system can handle.
netconcepts
Aug 25, 2005 09:28 PM
Qamar
Jul 26, 2005 06:25 AM
FRANCISCO
Jun 16, 2005 12:02 PM
wavewright
Apr 10, 2005 07:21 PM
djbaines
Dec 16, 2004 12:22 PM
