does this look
Old Nov 3, 2009 | 06:50 PM
s_moneh's Avatar
Default does this look
like it would fit/ come out of a 1997 850 turbo??
i'm jsut wondering because that looks like a damn sick cluster to put it if it fits and everything..... anybody seen this before??
http://cgi.ebay.ca/SPEEDOMETER-VOLVO...item20ad8d0931
Old Nov 3, 2009 | 07:02 PM
gilber33's Avatar
That's just a file photo. Meaning it's a default picture of a cluster. You would be getting your run of the mill cluster from an 850, not the one in the picture.
It is a sweet looking cluster though.
Old Nov 3, 2009 | 07:07 PM
s_moneh's Avatar
thats wat i thought, if it was liek that i'd buy it asap cuz its so cool
ehhh and by the way i actually got my second 850 t5 running, i spent 27$ lmao and shes roaring now
turns out it was the camshaft sensor that was bad, hit up a junker picked it up for 27$ and shes making noise, now i'm gunna redo everything
by any chance would u know where the STAGE ZERO thread is?
Old Nov 3, 2009 | 07:39 PM
gilber33's Avatar
No, but stage zero is pretty simple. All hoses, plugs, plug wires, cap, rotor, fluids, filters. Make sure everything is in working order, you don't want any "kinks" in the system, because what may seem small in the beginning, once you start modding can turn nasty real fast. If the miles are high, I would also look into new turbo gasket seals. Things like that.
Old Nov 3, 2009 | 07:56 PM
s_moneh's Avatar
plugs- check
plug wires- check
cap- check
rotor- check
hoses- which hoses exactly? or just make sure there not broken?
fluids- oil/ tranny? all thats in the works
filters- have 1 of 3
and yes the miles r high, how do i go about the turbo gasket seals? is there a write up on how to do it and where to get some stuff?
Old Nov 3, 2009 | 08:09 PM
gilber33's Avatar
Turbo and coolant hoses, especially with a higher mileage car, oil starts to travel through the system and get in the hoses which causes them to deteriorate. Check all of your rubber hoses to make sure they are not spongey (this could very well be the most expensive part of stage zero, but very important). Especially if you start running more boost and pushing the car, it causes the hoses to expand more, which runs the possibility of blowing a hose higher.
For the turbo return line, there's a small gasket on the bottom of the turbo that is known to go bad, just look at the bottom of your turbo and if its dry you have nothing to worry about. And if it is, it's a real simple DIY fix.
Old Nov 3, 2009 | 08:32 PM
The stage zero thread should be in one of the sticky's.
Old Nov 3, 2009 | 08:35 PM
gilber33's Avatar
You're a sticky
jethrobodean
Feb 16, 2013 07:50 PM
Illadelph
Jan 24, 2012 07:33 PM
Italiano86
Nov 6, 2007 12:10 AM
ludeless
Jan 23, 2006 10:16 PM
