Does tire speed rating matter?
Old Jan 14, 2005 | 01:54 PM
guptash's Avatar
Default Does tire speed rating matter?
1995 850 Wagon - non-Turbo
Volvo recommends V-rated tires, what will I loose or risk if H-rated were put into it. Some stores refuse to even put in H-rated when manufacturer recommends V-rated, others do not care.
Advise or opinion is needed.
Old Jan 14, 2005 | 02:22 PM
Default RE: Does tire speed rating matter?
The speed rating will only matter if you are planning on driving on the autoban.V rated tires are rated to I think 170mph and the h rated to I think 140mph.When I worked at the dealership we would replace V rated tires with H rated all day long.
Old Jan 14, 2005 | 04:37 PM
guptash's Avatar
Thank you, that helps. I drive this car to work and back and within speed limits and therefore will get H-rated tires.
Old Jan 14, 2005 | 05:11 PM
You may not even feel the diffrence between the tires.There is not problems with installing the H-rated tires.
YOUR WELCOME
Old Jan 14, 2005 | 05:29 PM
cwworth's Avatar
No probs unless you live in the UK or Germany where fitting tyres which differ from the manufacturers recommendations can invalidate your insurance. [:-]
Old Jan 31, 2005 | 03:55 PM
guptash's Avatar
Thank you for all the advice. The h-rated tire work great, good smooth ride.
Old Jan 31, 2005 | 04:24 PM
No problem anytime.
comrade904
May 10, 2012 08:58 PM
AlanS
Apr 1, 2011 10:20 AM
JimBee
Sep 28, 2010 02:15 PM
drongo
Oct 29, 2009 12:35 PM
Chuck007
May 21, 2009 02:05 PM
