Dreaded Air Pump Problem
Old May 31, 2008 | 09:52 AM
thelaststallion's Avatar
Default Dreaded Air Pump Problem
I have a Volvo 850 GLT 1996. So my check engine light went on awhile back and it was the Secondary Air Injection System PO140. So I replace the air pump and tested the air pump to see that it is working. I tested the SAS Check valve and it is working. I just replaced the air pump relay and the pump is still not coming on. The only thing I can think is that the relay is not switching on, what would cause this? I pulled off the cover to the fuse panel by the firewall and see some relays, but I can't find a specific fuse for the relay. Is there a fuse I need to check in a place other than the fuse box under the hood?
I appreciate any help.
Old May 31, 2008 | 10:25 AM
Default RE: Dreaded Air Pump Problem
The air pump only comes on when the car is really cold.
Are you testing cold?
Old May 31, 2008 | 10:31 AM
JPN's Avatar
JPN
My '94 T5 didn't have the air pump set-up so I have absolutely no knowledge on the system. And I could not locate the relay for the SAS. Wait for other members' replies.
JPN
[IMG]local://upfiles/6892/8B5AC5A31EC84C15B8E34DFC0AF41E54.jpg[/IMG]
[IMG]local://upfiles/6892/B1205160E6124751A3867E58DCAD6303.jpg[/IMG]
Old May 31, 2008 | 11:43 AM
I've tested the pump and know it works. I've tested the relay and know it works. I've tested the SAS valve and know it works. The valve opens and the air pump doesn't come on to pump air into the exhaust. On the relay there are three wires: one wire turns hot when the ignition is switched on, one wire is power for the air pump, and the other wire is a switched ground wire. The switched ground wire never gets grounded and the relay never switches and the air pump never turns on. I don't know where the switched ground wire goes, but if I knew I'd be closer to the answer.
Thanks again for any help
Old May 31, 2008 | 12:09 PM
The ECM switches the ground when the coolant temp is below a certain temp. That is what makes the air pump come on.
Old May 31, 2008 | 12:12 PM
I really need a wiring diagram. I specifically need to know what wires come out of the ECM.
MAXREES
Sep 3, 2023 05:37 AM
peaceablegarden
Jul 27, 2013 10:45 AM
turboxr
Dec 17, 2011 12:35 AM
newsboy121
Aug 25, 2005 10:58 PM
Ty
Jul 1, 2005 10:22 PM
