...dried out but still "chugging"...
Old Apr 25, 2009 | 11:09 PM
trooperone's Avatar
Talking ...dried out but still "chugging"...
I have a 94 850 (non-turbo) that I bought about 6 months ago. It has 114k miles on it, and a few days ago, (as I have previously posted about), I cleaned under the good really good, and got it really wet. It had ran perfectly before that day, and now, especially from a stop, accelerating makes the car "chug", if you don't just go really lightly on the accelerator and let it build up speed. Per your recommendation, I pulled the plug wires, and sure enough, found that plug 2 and 3 were a little wet. I dried them really well, and though it is better, still have the "chugging". I have decided that since the plugs look a little "burned" (the previous owner had put Champion plugs in it...eeeeeks!!!), that I am going to go ahead and change the plugs, wires, distributor cap, and rotor. This brings me to my 2 questions......do you know of anything I am "missing" that I also need to check regarding the "chugging" problem, and also....I thought I would go back with genuine Volvo parts, unless you recommend a better solution. Thanks a bunch!!!! We have 4 of these cars, and you guys are real lifesavers to me!!
Old Apr 25, 2009 | 11:25 PM
I always use the OEM tune up parts. I like them better than the cheaply made aftermarket ones.
Old Apr 25, 2009 | 11:28 PM
trooperone's Avatar
Great! I agree with ya! ALSO....can you think of ANYTHING else I need to check out regarding this "chugging" problem besides just doing the tune up? Thanks again!
Old Apr 26, 2009 | 06:20 AM
That should be it.
Is the check engine light on?
Old Apr 26, 2009 | 09:30 AM
Psaboic's Avatar
Did you check under the distributor cap?
Old Apr 26, 2009 | 09:58 AM
trooperone's Avatar
OK---THANKS!! No, the check engine light is NOT on. I checked under the distributor, and it looked fine...dry as a bone.
09XC90
Feb 5, 2019 02:11 PM
charlesd
Oct 28, 2011 07:02 PM
jenn
Jun 12, 2011 01:21 PM
09XC90
Oct 17, 2009 07:01 AM
trooperone
Apr 16, 2009 06:24 PM
