94 850 non-turbo "chugging"
Old Apr 15, 2009 | 05:01 PM
trooperone's Avatar
Question 94 850 non-turbo "chugging"
Well.....I know I must have messed up something...but don't know where to begin. Yesterday, I detailed my car and cleaned under the hood really well. It at first wouldn't start back up, then after sitting about an hour, fired right up, at which point I just parked it in the garage. Today, I started the car (it did fine), and was driving it (going about 7 miles), and it started "chugging" at low speeds, and dying at stop lights. Accelerating from stop, it acted like it was "misfiring" really bad, and had to keep it revved to about 3000 to keep it running, while shifting it into neutral, to make it back home.
SOOOOOO.................I am presuming I am going to need plugs, wires, coil, or ????????
By the way, NO codes are coming up at all. Where do I begin? Thanks a million!!
Old Apr 15, 2009 | 06:33 PM
Johnny Mullet's Avatar
Start by popping off the distributor cap and inspect in there.
Old Apr 15, 2009 | 07:26 PM
trooperone's Avatar
Hi and Thanks! I pulled the distributor cap.....dry as a bone inside. Also the wires plugging into it are all dry. So........next????? GEEZZZZZZ....remind me to leave the dadgum thing dirty under the hood...ha!
Old Apr 15, 2009 | 09:09 PM
Pull the wires from the plugs and I will bet you find water in the holes around the plugs.
Old Apr 15, 2009 | 10:55 PM
trooperone's Avatar
OK thanks!! If I should find water there, I suppose just drying the area good will be OK...or do I need to buy new plugs, also? I will if they look burned, obviously, but I mean, if they LOOK ok...is it going to be OK to just make sure that they and the area around them are good and dry? Thanks!
Old Apr 16, 2009 | 07:46 AM
bestharry's Avatar
You should be back in bussiness if you clean and dry all the cables and spark plugs really nice.
Old Apr 16, 2009 | 06:24 PM
Dry it really good and you will be fine.
CaliVolvo
Sep 18, 2013 02:52 PM
2003volvov70
2001-2013 model year V70
Mar 31, 2013 03:30 AM
Bobb
Mar 16, 2013 04:46 PM
Rosew6211
Oct 9, 2010 07:18 PM
trooperone
Apr 26, 2009 09:58 AM
