Drivers door latch actuator pictures / diagrams needed
Old Jun 17, 2013 | 10:24 AM
johnwartr's Avatar
Default Drivers door latch actuator pictures / diagrams needed
I went to the pull a part over the weekend, and picked up a drivers door handle assembly.
I enjoyed rekeying the tumbler to match my key. It was pretty easy.
In the process of removing the original handle from the door of my car, I did things out of order, failing to remove the lock cylinder before removing the handle itself.
Because of this boneheaded move, I believe I broke something in the lock section of the latch assembly.
I took the door apart, and was able to get the latch/actuator part out of the door. I'm referring to the part that the outside and inside handles pull the open the door, as well as the part the post off the lock cylinder pushes into to unlock the door.
There's a white plastic sleeve of sorts that the post on the end of the lock cylinder slides into, and turns to unlock the door. Mine came apart. It appears to be 2 pieces. I put them back together, but I'm not 100% sure I put them together *right*.
Does anyone have a photo of this part? Or a diagram? I'd like to see how it's all supposed to work together. Perhaps I damaged the plastic parts, and need to order some bits or hit the pull a part again and grab more bits.
Thanks!
mafraziersr
2001-2013 model year V70
May 30, 2015 04:10 AM
Flow313
Nov 26, 2014 08:09 PM
Aesthetikz
Nov 17, 2010 10:46 PM
ShaginWagon
Jan 20, 2008 04:56 PM
HRoberts
Jan 5, 2008 12:54 PM
