850 turbo cut off, won't start
850 Turbo was running well. A couple mornings it started a touch roughly with a bit of gray/white smoke. Then the next afternoon, took a corner and it stopped running. Will crank, but not fire. Checked and changed the fuel filter, which was fairly dirty. Filter has refilled with fuel, so I guess the fuel pump is ok. Changed the spark plugs. Can't get it to turn over. Thoughts?
