driver's side front end problem
Old May 30, 2011 | 10:12 AM
962ym's Avatar
Default driver's side front end problem
Hello all, I'm having a problem with my 97 850 T-5. When I turn the wheel all the way to the left, the driver's side tire rubs against the lip of the fender and will bend it out. Also, when going over bumps, the driver's front bottoms out. I have new springs and struts. Any advice would be appreciated.
Old May 30, 2011 | 01:24 PM
91shelby's Avatar
how old are your ball joints? i had a similar issue with my 95 and my ball joints were loose as hell
Old May 30, 2011 | 03:18 PM
MattyXXL's Avatar
Does it bottom out or just sound like it bottoms out? Did you replace the spring seat when you did the springs and struts?
Did you put lowering springs on or stock height?
also, You can ball out your fenders, a wood bat can do it or you can get someting like this.. ===>Eastwood Fender Roller Tool
A little more complicated than the bat method but ive used it and love it..
Markvolvo
Dec 29, 2013 01:23 PM
BillLisa
Jun 27, 2011 11:29 AM
LovemyS80
May 28, 2011 04:30 PM
epgiles
Apr 6, 2009 06:59 AM
drum
Aug 13, 2007 10:08 PM
