Dropping the Fuel Tank
Old Apr 2, 2011 | 12:21 PM
91shelby's Avatar
Default Dropping the Fuel Tank
Im going to drop my tank this weekend to repair some of the evap and overflow lines that are cracked and tips an tricks to dropping it?
Old Apr 2, 2011 | 01:02 PM
MattyXXL's Avatar
This is on your 95 850?
Besides making sure the tank is empty....
Here is a PDF form vadis on the removal maybe it will help ------>95Turbo_Tank_Removal.PDF - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
There is also a write up on MVS---->http://www.matthewsvolvosite.com/for...=23851#p104418
Old Apr 2, 2011 | 01:11 PM
91shelby's Avatar
yeah, otherwise id post in the 960 forum :P whats the best way to empty it?
Old Apr 8, 2011 | 05:46 AM
arzy's Avatar
Go for a long long drive
Old Apr 8, 2011 | 08:17 AM
boxpin's Avatar
With fuel the item links below would be a one time use since they were designed for water. I would drive it to get the majority out. You could probably manage it from there just if you dont want to get it all out but if you dont be sure to use some good support under it.
Fluid Siphon Pump
or
Multi-Use Transfer Pump
or
All Purpose Drill Water Pump
or
The one I have is a two gallon hand pumped vacuum tank but I cant find it on their site now. I can tell you its blue ;-)
Old Apr 8, 2011 | 09:12 AM
Our S70 has a valve stem at the fuel filter. Can't you just remove the stem from there and pump it out (jump the fuel pump), or pump it out through the rail ?
Old Apr 8, 2011 | 12:30 PM
MattyXXL's Avatar
Either that or remove the fuel filter line and jump the pump also..
Old Apr 8, 2011 | 02:13 PM
91shelby's Avatar
how to jump the pump?
Old Apr 8, 2011 | 02:18 PM
MattyXXL's Avatar
you should be able to just turn the key to the on position i think..
Old Apr 21, 2011 | 12:26 AM
91shelby's Avatar
would a cracked overflow/vent line to the tank possibly cause lower MPG?
AnEskimo
Oct 7, 2010 07:28 AM
nicolaselias
May 17, 2009 10:43 PM
kevmcrae
Apr 25, 2009 11:25 PM
paulw4
Mar 20, 2009 02:17 PM
bigmay850
Mar 28, 2007 11:20 AM
