ECC Codes
Old Jul 15, 2013 | 07:38 PM
97black850's Avatar
Default ECC Codes
Can someone explain how to pull the codes on an Electronic Climate control unit? I have read some, but I'm still confused. It has the two flashing lights at start up.
Old Jul 15, 2013 | 08:50 PM
I believe you will need special Volvo code reader or some good OBD 2 computer software with a cord.
Old Jul 19, 2013 | 11:00 PM
97black850's Avatar
On my 94 Turbo I pulled three codes for the climate control:
1. 1-2-4Driver’s side interior temperature sensor open circuit or shorted to 12 volts
2. 4-1-7 Passenger’s side interior temperature inlet fan seized
3. 4-1-8 No control signal to blower fan power stage
Has anyone experienced any of these issues before? Help is greatly appreciated in this heat wave!
Old Jul 20, 2013 | 04:56 AM
scutyde's Avatar
Nr 2. is a "standard" error normally the driver side is also present.
Above the handles on the roof lining there are 2 small holes. Behind them there are 2 small fans which measure the temperature in the passenger comparment. They usually get clogged over the years, faster if there is a smoker in the car
Sometimes it helps to clean them (very carefully they are very sensitive), but there are a lot of reports where cleaning only helps for a short period of time.
Clear the errors and then see which one returns. Maybe there are some old errors.
Cristian
Old Jul 20, 2013 | 08:16 AM
97black850's Avatar
Okay, thanks!
Old Jul 20, 2013 | 09:48 AM
97black850's Avatar
I was out looking. Do you mean the two small holes near the rear of the car above the back handles? I am still a little confused.
Old Jul 20, 2013 | 06:06 PM
97black850's Avatar
cleaned both of them and i am still getting the code. at a loss on it
Old Jul 20, 2013 | 09:26 PM
Instructions for cleaning the interior temp sensors and fan with pictures if you sign in: http://www.matthewsvolvosite.com/for...hp?f=1&t=32617
Have you tried to Google those codes or the code description to see what you can find ??
The part itself: 9145736 Genuine Volvo - Temperature Sensor - Interior - Free Shipping
Old Jul 21, 2013 | 12:34 AM
97black850's Avatar
not as much as the fan. i was trying to tackle one at a time. thank you for the link because i couldn't find it. now it is making a buzzing sound so im not sure if something got knocked loose or what
Old Jul 21, 2013 | 05:35 AM
My control is flashing and my car gets to cold. My guess is that I have a bad sensor or two. I guess I'll read the codes.
Old Jul 21, 2013 | 07:11 AM
scutyde's Avatar
From VADIS:
1-2-4
Condition
If signal from passenger compartment temperature sensor is missing or shorted to 12 V, the control unit records the fault and stores the DTC.
Possible source
Open circuit in passenger compartment temperature sensor or wire, or short in wire to 12 V.
Fault symptom(s)
Fault warning to driver. LEDs by A/C and REC buttons flash for 20 sec.
The control unit substitutes the faulty signal with an estimated value based on the desired temperatures from both temperature switches and the sensor signal from the side which is working. If the sensor signal is faulty on both the driver's and passenger side, the control unit uses the temperature value from that side's temperature switch only.
4-1-8
Condition
If there is no control signal to the passenger compartment fan power stage, the control unit records the fault and stores the DTC.
Possible source
Open circuit in wire between control unit and passenger compartment fan power stage or internal fault in passenger compartment fan power stage.
Fault symptom(s)
Substitute value
Control unit substitutes a preset value of 4 V equivalent to a 28% speed setting on the passenger compartment fan.
Old Jul 21, 2013 | 08:18 AM
97black850's Avatar
Great info! thanks again
Brick850
Sep 8, 2013 08:09 AM
ded137t5r
Dec 17, 2012 05:12 PM
mt1o1n1e
Oct 23, 2009 06:25 PM
lister99
Jul 5, 2008 11:36 PM
axelm
May 27, 2008 09:19 AM
