ECC DIY power stage repair
Old Sep 18, 2007 | 04:59 AM
J Telectro's Avatar
Default ECC DIY power stage repair
Hi everyone,
I know that several people have had trouble with their ECC modules
and have had to replace them. I ran across the following article that
explains how to repair the power stage in the ECC(?) units. I don't
know if this also applies to the blower motor resistor in the MCC
units as I've never seen one.(I guess I should take mine out sometime
and see what is actually in there).
Maybe tech or someone familiar with these units can verify which
modules this applies to.
The link:
http://www.brickboard.com/AWD/index.htm?id=1202115
I haven't tried this so try it at your own risk.
Hopefully this will help someone save some money.
Best regards, John
Old Sep 18, 2007 | 05:31 PM
Default RE: ECC DIY power stage repair
That is only the blower motor resistor.
It is for both ECC and MCC systems. But some years had different ones.
Old Sep 18, 2007 | 07:08 PM
J Telectro's Avatar
All right! That part is used on a lot of cars. I bet you can get a
replacement transistor for a lot less than buying the whole resistor
module. I thought the resistor module was a special tapped power
resistor...that's what I get for assuming things.
Thanks, John
Lewmer
Oct 29, 2025 12:41 PM
WaltL
Jan 18, 2011 07:06 AM
pinocs
Sep 18, 2009 07:14 PM
Frodo
May 29, 2006 05:55 PM
jfunez
Mar 5, 2006 03:16 AM
