Ignition Trouble - Bad Power Stage?
Old May 29, 2006 | 12:44 PM
Frodo's Avatar
Default Ignition Trouble - Bad Power Stage?
I have a 1988 740 GLE that just died on the freeway the other night. I had the car towed home and have found that I am not getting any spark out of the coil. I am getting power to the coil from the igintion switch but nothing comes out of the coil. Two years ago, I had the same problem and I tried replacing the coil but this didn't solve it. The electrical schematic showed something called a Power Stage but I couldn't locate it. Finally I towed the car to a local Volvo specialist where they found that it indeed was the Power Stage or Power Amplifier as they called it. It is located on the left fender wall behind the air filter housing (in case anyone else is looking for it). Anyway, the car seems to have the same symptoms so I suspect the Power Stage again but the darn thing costs $143. I hate to buy a new one and find out I was wrong because they usually don't allow returns on electrical parts. Does anyone know how to check a Power Stage to see it it is good? Can you measure resistance across certain cables?
Help.
Thanks,
Frodo
Old May 29, 2006 | 05:55 PM
Default RE: Ignition Trouble - Bad Power Stage?
Also check the engine speed sensor if your car has one. If it doesn't look at the electrical plug on the Dist.
Lewmer
Oct 29, 2025 12:41 PM
WaltL
Jan 18, 2011 07:06 AM
pinocs
Sep 18, 2009 07:14 PM
J Telectro
Sep 18, 2007 07:08 PM
jfunez
Mar 5, 2006 03:16 AM
