Electrical fault
Old Jul 20, 2008 | 07:47 PM
bowser's Avatar
Default Electrical fault
Unfortunately I don't have an owner's manual for my 93 850 sedan so need some advice. I had a new battery installed and it appears to be faulty as it went flat for no apparent reason. I placed a charger on the battery but now am unable to get the car to start. The engine turns over but there are no warning lights or gauge movement and it appeasr that either or both no fual and no spark is present. I have checked the normal fuses and can't see one that has blown. Is there a main fuse or breaker that may have been tripped that controls engine functions? Or is it worse and I have cooked the computer somehow?
Main problem solved. I had burnt out a relay which has been replaced and nearly everything is AOK. However I still don't have power to the windows. Do they have a relay as I can't seem to locate the fuse for these?
Old Jul 21, 2008 | 08:07 AM
Ozark Lee's Avatar
Default RE: Electrical fault
Power for the windows runs through overload relay #3 (One of the "J" relays) and then to circuit breaker #37. The circuit breakers are supposed to automatically reset.
You can download your owners manual here:
http://www.volvocars.com/us/tools/Ow...s/default.aspx
...Lee
Old Jul 21, 2008 | 08:31 AM
Psaboic's Avatar
Do you know what caused the initial relay to blow? +1 to the tip on the overload relay
Old Jul 21, 2008 | 02:02 PM
Quick Brick's Avatar
You see!
This is why I love this forum.
There is so much honest to goodness help here that it almost makes me feel really good.
Ask and ye shall find.
This is how the internet is supposed to be used
Old Jun 23, 2010 | 01:54 AM
TMG's Avatar
TMG
Unhappy have spark and fuel but wont start
91 stwgn has been dwn for a month. get spark and fuel but wont run if it does start as soon as you put it into drive it stalls. before it died totally it would run good then it would run rough and some times die at a stop but never in park,Now it wont start at all all kind of relays have been changed new wires coil distributor you name it my father inlaw has been working on it and is stumped. please help
v1lcins
May 20, 2022 10:53 AM
Bri
Feb 25, 2011 02:56 PM
tonyrs60
Sep 24, 2009 09:06 PM
Revolvoer
Mar 23, 2008 06:59 PM
GaryW
Oct 21, 2003 05:26 AM
