Black plastic foot rest "pad" keeps poping off
Old Jun 21, 2010 | 09:05 PM
ajahn's Avatar
Default Black plastic foot rest "pad" keeps poping off
I purchased that little black plastic foot rest "pad" that on to the left of the break pedal. It is supposed to install into 2 holes. It doesn't stay; keeps popping off. Is there a trick? I've tried pushing it in then sliding it down, but it doesn't stay.
Any suggestions would be appreciated.
Thanks
Old Jun 21, 2010 | 09:19 PM
gilber33's Avatar
double sided sticky tape?
Old Jun 21, 2010 | 09:33 PM
There is suppsed to be a tab that locks into the hole to hold it in.
Old Jun 21, 2010 | 10:22 PM
ajahn's Avatar
I see a little tab, but I can't figure out how to get it into the hole. Is there some trick?
The holes look like this:
But the tab is to the bottom of the thing that goes in the bottom hole. Unless you have to bend the piece to get it in....
Old Jun 21, 2010 | 10:27 PM
Once you put the pad in did you slide it up? If not then slide it up and it should lock in the hole that you originally put the round tab into.
Old Jun 21, 2010 | 11:40 PM
ajahn's Avatar
It looks like the round tabs sticking out of the bottom of the pad is the size of the large hole, so when I slide it up it doesn't appear to move much in that direction. I'll still give it a try. I will take some pictures tomorrow and post them to show what I'm talking about.
Thanks
Old Jun 22, 2010 | 02:45 AM
Legendsecko87's Avatar
Buy a new one, they're cheap.
Old Jun 22, 2010 | 06:30 AM
ajahn's Avatar
I did buy a new one. But I'm having trouble installing it... Someone suggested I slide it up. Any other advise on getting it to stay in place?
Thanks.
Old Jun 22, 2010 | 09:26 AM
vjaneczko's Avatar
Probably just have to give it a good upwards shove to get it to 'lock' into place - you may even need to tap it with a hammer if its real tight. Just make sure that both 'fingers' are seated through the holes before you shove or it won't fit properly.
Old Jun 23, 2010 | 07:41 AM
ajahn's Avatar
That did the trick! Thanks for all the help.
bawilliams
Feb 26, 2011 08:01 PM
timwu12
Jan 27, 2010 01:15 PM
car54
Aug 13, 2009 11:13 PM
timwu12
Apr 11, 2009 09:14 PM
Inlinesix
May 13, 2008 05:56 AM
