end link
Old Aug 5, 2008 | 06:03 PM
sheriffjohn's Avatar
Default end link
[:-]i am removing my strut i know the end link must be disconnected but it is under tension.can anyone tell me how to remove this tension.i tried vallium but it didnt work thanks.
Old Aug 5, 2008 | 06:10 PM
Default RE: end link
If you are only doing one side just remove the nut then press the sway bar down a little and remove the link.
Old Aug 5, 2008 | 06:35 PM
i tried using a pry bar but it wouldnt move
Old Aug 5, 2008 | 06:37 PM
Did you have the nut off already? If not remove the nut first. Then it will drop some for you to slide it out.
Old Aug 5, 2008 | 06:44 PM
thanks
Old Aug 5, 2008 | 06:46 PM
No problem.
91shelby
Apr 6, 2012 04:19 PM
RedS70guy
Dec 9, 2010 03:19 PM
Bruno937
Mar 8, 2009 12:41 PM
