engine light on
Old Jan 31, 2008 | 05:22 PM
Trevoro's Avatar
Default engine light on
okay here is what I have, the mil light is on code for system to rich,p0172, and evap system malfunction. Purge vsv seems ok, at time of code fuel trim was -25%. If car is idling fuel trim looks good, +/- 5%. any ideas? no "smoke" when I remove oil cap or dipstick. Fuel consumption is a little worse aswell.
oh yeah it is a 1995 850 turbo wagon.
Old Feb 1, 2008 | 06:43 PM
Default RE: engine light on
Check for vaccum leaks.
Old Feb 3, 2008 | 06:06 PM
Trevoro's Avatar
wouldn't that cause a lean code?
i was thinking if the purge vsv stuck, perhaps it could cause a rich code
any ideas?
Old Feb 3, 2008 | 06:23 PM
It would make it start to run lean till the computer over compensated for it making it run rich.
Check all vaccum lines really good espically the one on the end of the intake if it has one behind the power steering pump.
Old Feb 3, 2008 | 07:25 PM
Trevoro's Avatar
thanks, will look there.
tngreg
Sep 5, 2022 07:27 PM
nealeas
Mar 24, 2018 09:59 AM
s80kid
Jan 22, 2011 11:12 AM
ErnstlS90
Oct 23, 2008 08:37 AM
