Engine Rebuild #2
Old Jan 20, 2010 | 08:25 AM
radio16's Avatar
Default Engine Rebuild #2
well i found my problem-- i need to replace cylinders 4&5 piston rings - i ordered a full set so ill just go ahead and do all 5 - smart idea i want to fix it 1nce and for all - shes my baby-going to do the pistons with engine in place - i dont have a lift to pull engine and no money to rent one - it shouldnt be tooo awfully difficult i dont think - i can get to the bolts from oil pan and push pistons up and out - this will fix my crankcase pressure problem finally and then i can get on with life -- i will try to post pics as i go along
1 quick question -- my piston configuration is D-D-E-E-D WILL STANDARD RINGS FIT THEM ??
QUICK RESPONSE FROM ANYONE THAT KNOWS THANX
i dont want to get them in set of 5 if they dont fit but it says its the standard set so ifts all i guess
Old Jan 22, 2010 | 04:44 PM
radio16's Avatar
Default Update
well got the oil sump out after much trial and tribulation - removed all the pistons and they were burnt up pretty badly ( the rings were ) also found that the bearings were scored really bad as if someone threw a bag of sand in the engine - oil pan had what appeared to be sand in it even after first clean out
all clean now - new rings installed -waiting on bearings / head gasket and head bolt replacements ( that was an expensive mistake with the head bolts)
assembly begins when they arrive'
Old Jan 24, 2010 | 10:01 AM
kv893t's Avatar
Smile
well i am sure glad to fine your post.i have a 95 glt that looks just like yours
and have the same problem.i have done a complete top end job.but now i fine that a ring job a must.i know the top end will have to be remove again but can u tell me what are the pit falls to replacing the rings and what i should be looking out for and if i have to replace the head bolts and head gasket i just replaced.i know this is your thread but maybe u wouldn't mind sharing your
experience at this time.thanks so much
sjackson
Oct 25, 2018 05:49 PM
nmt0m35
Mar 20, 2009 08:29 PM
silverv70
Mar 14, 2009 12:35 AM
RED MOFO
Jan 17, 2009 04:45 PM
axis72
Feb 11, 2006 05:29 PM
