engine swap
Old Feb 15, 2013 | 08:47 AM
silver ghost's Avatar
Question engine swap
Hello I posted in engine& internal a question about swapping an engine in my1997 850 non turbo wagon . I found an engine from a 1998 70 and was wondering if I could put it in my wagon ? would anyone know if it the engine will mount up the same are they compatible/ inter changeable ? thank in advance for you input.
Old Feb 15, 2013 | 11:38 AM
MattyXXL's Avatar
is the 98 70 a N/A also?
if so it is the exact same motor, they changed in 99+
Old Feb 15, 2013 | 03:16 PM
thanks mattxxl thats what i needed to know i did not want to buy it and be stuck with a motor i could not use .
Old Feb 15, 2013 | 03:27 PM
MattyXXL's Avatar
**** you can use a 2011 motor you just need to swap alot more over..
Old Feb 16, 2013 | 05:13 AM
I really don't want to change more then I have to. I would like to just drop it in and not have to swap that much over. The engine I found has 122,000 on it which I don't think is a lot considering I have 329,000 on the engine that's in my car know that was running tops. It would have a lot more had I changed the water pump when I did the timing belt. It's my fault I killed the car should have spent the extra money for the pump, but it had no sign's it was going. I know everyone say's to replace the pump when doing the belt that's my fault know I have to do a transplant.
Old Feb 16, 2013 | 05:35 AM
How many miles do you think was on the pump? Did it ever leak?
Old Feb 16, 2013 | 05:39 AM
I bought the car with 143.000 on it for $3000.00 and put almost 200.000 on it all highway miles and never replaced it and no it did not leak i must have gotten a good pump. I know that I should have put at least 3 or 4 pumps in it already but there was no signs that it was going . I have changed the oil every 3.000 done numerus tune ups lots of brake jobs. My father used to say don't fix it unless it's broke I should have replaced the pump okay i am stupid .
Old Feb 16, 2013 | 05:58 AM
lesson learned this new motor will be different on replacing the pump. I want to see how many miles I can get out of the engine. It is like a game I love these car's, my neighbor's son was so happy when I spun the belt because the car died he's all ready killed like 5 car's from the day I pick up this one but she'll be running soon and passing him on the highway again.
Old Feb 17, 2013 | 06:29 PM
Hello rspi $ mattyxxl, I want to THANK YOU BOTH for your input. I went today with my son and picked up the motor. The person I picked it up from had a vidio of the motor running just before he removed it pirrrring like a kitten. It has 113.000 on the odometer .Well of course we had a snow storm today about 9" fell, so I am going to have to wait till the snow disappears before I can replace the engine I will be posting back. THANK YOU AGAIN.
JDvolvo33
May 16, 2012 09:53 PM
McQuattro
Jun 19, 2009 07:29 AM
bsamole
Apr 26, 2009 06:27 AM
Superfly
Sep 22, 2005 09:37 PM
s60r
Aug 13, 2004 03:39 PM
