Error Code A2 4-1-3 EGR Temp Sensor
Old Nov 4, 2006 | 05:30 PM
MikeySq's Avatar
Default Error Code A2 4-1-3 EGR Temp Sensor
Hi I just pulled code A2 4-1-3, EGR temperature Sensor signal absent or faulty, from the car.
What would be the plan of attack of checking out this code.... where might this sensor be and how is it tested?
Thanks
Mike
Old Nov 4, 2006 | 06:07 PM
Default RE: Error Code A2 4-1-3 EGR Temp Sensor
The sensor sticks out of the EGR valve.
Not sure how to test without the Scanner reading the signal.
But I do know the Sensor is very expensive almost $200.00 last time I checked.
Might want try to find a used EGR and just swap it out.
Old Nov 4, 2006 | 08:36 PM
MikeySq's Avatar
I just saw the price of that sensor on FCPGrotton... $192. Well that's a chunk haha I'll check for wiring conditions and maybe see if I can try a used one on in there.
What are the results/effects of an EGR system that is not working that great?
http://www.fcpgroton.com/volvo850other.htm
Old Nov 5, 2006 | 12:09 AM
JPN's Avatar
JPN
Hello Mr. MikeySq,
Greetings from windy Chicagoland.
EGR valve is meant to return a part of exhaust gas back into the intake side. This reduces the combustion temperature and lowers emission byproducts (according to smart engineers). It also gives unburned fuel another chance to get burned.
I think the effects defer from car to car. Some car may stumble or stall, while other cars run fine, except the emissions may be higher than normal and you'll get that annoying "Check Engine" light. Some cars may also suffer drop in fuel economy.
I wonder if there are some effective ways to clean/repair these sensors. They are overpriced, regardless of what sensor (O2 sensors are almost $200 each, and 850s have two of them!).
Good luck,
JPN
VTBricked
Dec 30, 2009 09:11 PM
landrover7297
Oct 21, 2009 10:08 PM
Erich73
May 19, 2009 11:40 PM
burnferris
Feb 8, 2009 04:43 PM
aarp guy
Mar 19, 2006 08:57 PM
