ever do a tranny in an 850?
Old Nov 21, 2006 | 06:22 PM
dannydoo's Avatar
Default ever do a tranny in an 850?
How long of a job is to change a 94 autobox 850turbo?
Anyone have any tips or recomendations?pics or links?
This is my first volvo ever touchhed.
I most likely can do tis on a lift or on my
Old Nov 22, 2006 | 10:26 PM
JPN's Avatar
JPN
Default RE: ever do a tranny in an 850?
Hello Dannydoo,
In regard to your question:
Too long, I don't even want to think about it (a few hours for dealer, several hours for me I assume).
If I were you, I would definitely get the Volvo factory manual before proceeding. Have sufficient quantity of Dexron-IIE(III)/Mercon. Mark all electrical/hydraulic connections to avoid mix-up later. Make sure no foreign object gets into the system, not even a tiny piece.
Good luck,
JPN
Old Nov 24, 2006 | 11:44 AM
The Dealer charges avout 10 hours to replace.
Old Nov 24, 2006 | 11:59 AM
info2x's Avatar
Never done a tranny and I don't want to until I have a nice place to do it. I would have another car handy or a way to get to a dealer, sears, Home Depot, or any other place in case as you suddenly realize you need something.
Old Nov 24, 2006 | 03:53 PM
dannydoo's Avatar
Theres 3 different 94 trannys?
The j/y told me the only difference between 94/95 is the converter is that true?
And I see alot of posts that 93 is the same as the w50-43le also.
If its a w 50-43le and its in a 93 or 96 shouldnt that be the same?Maybe not 96 I hear theyre obdII correct?
But would that even make a difference?
10hrs by the book is alot of work.
Is there an easier way?
Should I pull te motor/trans out from the top and do it?
Should I unbolt the sub frame and drop the whole mess on the floor?
Or should I try to wiggle out from the top?
or try to wiggle it out from the bottom?
Im suprised that not many people have experience being that the trans last from 50/200k and the motors do 200-400k
strange...
One last question. The plugs are set up so that you cant plug something ito the wrong socket right?
Or are thhey just color coded or something crazy??
Old Nov 25, 2006 | 11:43 PM
They are a PITA to do.
Best way is to support the engine from the top and drop the subframe.
There is many transmissions.
The Gear ratio's are different.
The transmisisons in the 1993 is 1993 only a 1994 won't work in a 1993.
Half of 1995 is OBDII
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
Psaboic
Feb 20, 2012 01:59 AM
tony67
Jul 3, 2011 02:27 PM
jrmcgove
Jul 8, 2010 08:15 PM
knight rider
Jun 4, 2005 02:00 AM
