Exhaust Question
Old Feb 17, 2012 | 10:50 PM
BigBear854R's Avatar
Default Exhaust Question
Starting to put everything back togther and had a question. I found the gasket for the manifold to turbocharger but I am confused as to if there should be a gasket between the exhaust side of the turbo and the down pipe ?
Also for the coolant/oil feed and return lines they have the threaded bolt for each connection, its been a while since I took it apart and can not remember if there should be a washer on each side of the bolt or just on the top side ? The ones I have only have the washer that fits against colar on each pipe ?
Old Feb 18, 2012 | 08:51 AM
gilber33's Avatar
No gasket between exhaust housing and downpipe.
I copper crush washer on both sides of the flange. One against the turbo and one against the head on the bolt.
Old Feb 18, 2012 | 10:34 AM
Just so I make sure I understand there should be a copper washer on the top and bottom and each coolant and oil line on the turbo center cartridge ?
Old Feb 19, 2012 | 06:02 AM
If you are talking about the "banjo" bolts then yes, you must have a copper (sometimes it's aluminum) washer between the head of the bolt and the line and the line and the CHRA face.
It's the same as for the banjo bolt on a brake caliper. Copper washer on both sides to make a seal. Always use new washers. I have got away with reusing them but never do it unless you just can't get new as it's not worth the risk it's going to leak.
Old Feb 22, 2012 | 09:53 PM
Anyone know where to get them at ???
Old Feb 22, 2012 | 11:55 PM
boxpin's Avatar
If you need them fast, Napa
Old Feb 23, 2012 | 03:30 PM
Or the Dealer. I haven't tried to look for them yet but maybe someone has a kit on Ebay.
turbowagon94850305
Jul 31, 2010 10:48 PM
Fluxmotoring
Nov 18, 2008 02:53 PM
mbemom
Apr 16, 2007 11:02 PM
cranky
Oct 17, 2006 09:14 PM
c70turbogt
Intake, Headers and Exhaust
17
Feb 12, 2006 03:21 PM
