expansion tank hose
It should work ok for you. Transmission hose is similar in ability to handle the temperature as I'm pretty sure transmission fluid gets hotter in normal use than coolant will and the pressure rating of the trans hose should be well above anything you'll see in the system as the radiator cap will limit it.
