Expansion Tank Question
Old Jul 21, 2008 | 03:23 PM
BriGuy's Avatar
Default Expansion Tank Question
Quick question. I have coolant dripping from a sensor on the bottom of the coolant expansion tank. I don't have time to pull the tank out and inspect it, but does anyone know hot the sensors mount in the tank? I'm wondering of they snap in or if one just need to be tightened if thsts possible?
Old Jul 21, 2008 | 05:29 PM
Ozark Lee's Avatar
Default RE: Expansion Tank Question
I recall that it just threads in.
...Lee
Old Jul 21, 2008 | 06:08 PM
The sensor just pushes in and locks.
Old Jul 22, 2008 | 07:52 PM
BriGuy's Avatar
Thanks. Maybe I can check it in my hotel parking lot tomorrow evening.
Old Jul 27, 2008 | 11:38 AM
green850's Avatar
my tank actually cracked at the fitting on the bottom, you might want to check that out. i had to pick up a new one at the junk yard
Old Jul 27, 2008 | 07:42 PM
BriGuy's Avatar
I've been travelling since last week. I'm hoping to be able to look at it this week, I just keep adding water/antifreeze as needed. I figure I wont have to change the antifreeze after a few weeks of that (kidding!)
Old Jul 27, 2008 | 08:47 PM
spioana007's Avatar
It just snaps in.
My tank was leaking this last week, and I bought a new one. (links below)
I also did the hoses connecting to the tank as long as I was doing the tank. I had cracks around the nipple on the tank that connects the small hose to the thermostat housing. It was ridiculously easy to swap the expansion tank, I was timid since I failed at trying to swap the O2 sensor...and thought there might be a lot involved in the expansion tank. The tank just snaps right out, you don't need to unbolt anything. And the sensor, and sensor tube snaps right out as well. You most likely have a crack in your tank. But I would inspect it and find the crack first.
I would just buy a new tank, the hose, and caps.
http://www.fcpgroton.com/product-exe...category_id/91
http://www.fcpgroton.com/product-exe...category_id/90
curtisckey
Sep 22, 2019 12:26 AM
jlhoward06
Feb 5, 2008 11:17 PM
AlX
Nov 19, 2007 03:23 AM
nebsch
Oct 9, 2007 09:03 PM
snulma1
Dec 28, 2006 11:19 AM
