expert advice please!!!!!!!!!!!!!!!!
Old Mar 19, 2009 | 06:52 PM
pete c.'s Avatar
Default expert advice please!!!!!!!!!!!!!!!!
thanks ... going to put cam cover (valve cover????????) back on after replacing the head... 2.3 t5 and haines manuel says apply volvo liquid gasket with a small roller, i dont know what this is !!!! can i use rtv silcone??????? please help..... i want to set cam timing tonite......once again thanks to all of you volvo guys ................pete
Old Mar 19, 2009 | 06:57 PM
Johnny Mullet's Avatar
In order to get the cam cover on, you also need special tools to compress the cover on. I made some with old spark plugs and welded bots to them to press it in. The sealant is available from Volvo. Use the special sealant.
Old Mar 19, 2009 | 07:05 PM
JPN's Avatar
JPN
Quote from the factory manual:
Using a roller, apply Sealing Compound (1 161 059-9) to
upper section of cylinder head. Ensure sealer does not penetrate oil
passages.
I would only use Volvo liquid gasket, but I've never done this job so wait for others' replies. Moderator Tech would be able to give you the best answer.
Sorry couldn't help you better.
P.S: Johnny got here a few seconds faster; good for you!
JPN
Old Mar 19, 2009 | 07:11 PM
nonsense619's Avatar
use the volvo gasket.it cures in the absence of air so make sure youre using the right stuff.its cheap..sand and clean both sides a bit to make sure they mate perfectly and just roll the gasket on with a lint free roller making sure none of the gasket runs into the channels.torque to specificaions in your haynes and your set.
Old Mar 20, 2009 | 07:20 PM
I agree only the Volvo stuff.
ethyre
Oct 7, 2010 05:29 PM
Lawbrum319
May 6, 2010 09:57 PM
Tmelysh
Jan 29, 2010 11:24 AM
pete c.
Apr 4, 2009 07:27 AM
pete c.
Mar 23, 2009 09:51 PM
